ATTN! all NRG 006 steering wheel users!
costa_rican13
Car: 1993 s13 coupe
how'd you get the the horn button to be still, and to not twist when you turn the wheel? mine just twists when i turn and i don't like that. i want it be vertical with the rest of the wheel.
biggie
Isn't the horn button attached to the wheel? Therefore will turn with the wheel?
costa_rican13
Car: 1993 s13 coupe
No its not. and does not turn with the wheel. this is my problem.
Razi
Car: Moo
Where is it attached then?
I don't see how it could not turn with the wheel.
My Nardi horn slips onto my steering wheel hub.
costa_rican13
Car: 1993 s13 coupe
No the wheel goes on, then the horn button, then center piece. and bolts on like that.
Razi
Car: Moo
My horn install was: Bolt on wheel -> Slip on horn
The Nardi horn has a spring that compresses, then presses against the sides of the steering wheel hub to stay put.
Are you sure the horn doesn't go in after the center piece is bolted on?
costa_rican13
Car: 1993 s13 coupe
Mine has 3 pieces. The bolts go thru the center piece (nrg ring) that holds the horn to the wheel and then the bolts go through the wheel and bolt up.
costa_rican13
Car: 1993 s13 coupe
Im not entirely sure if it does or not, but I mocked it up before putting the horn through last. And it doesn't seat it self against anything, so idk what to do.. I guess ill call nrg tommorow.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Install it and see, it will probably be fine when there is pressure applied.
costa_rican13
Car: 1993 s13 coupe
I did. and it turns I forgot the silver ring that hold the horn. so I put the ring on reinstalled everything and Bam it works great
