codyace »
https://forums.nicoclub.com/codyace-u28194.html
Thu Mar 15, 2012 9:33 pm
This research is certainly interesting, as on my personal car there wasn't any issue with overhang; my roomates car however did have overhang. I've often wrote it down to a slight casting difference between where the caliper bolts to the bracket, and the bracket then to the hub itself. With that said, the ORIGINAL Z31 covnersion was from FreshAlloy, almost 6-7 years ago (stating non turbo brackets), one that I helped update and brought over to Zilvia, which was then transposed here.
TO consider this modification unsafe for all of them is very questionable (to me). Again, according to the above research, my car should have crashed and killed itself twice now, as my car has no overhang (which would be indicative of the 87-89 setup...although I have NO clue what year my brackets came from, nor did I know the rotor type as it was already stripped)....and with that all considered, I've burned though two sets of pads now...and this isn't from street use, but track time. Thi leads me to believe there is still a casting difference between the NON turbo ones.
With that said though, I will be measuring the difference first hand to see how close it gets. Again, I'm not saying that LoserCard's information is wrong...it could very well be correct (as Iv'e not researched it nearly as in depth as he has)...but my personal setup has been wore to the rivets, without any qualms, and that's with what I think looks like a NON TURBO bracket, but with no Overhang (using carbotech pads). I would NOT suggest using a TURBO bracket, as that does look very iffy at best...that I would agree is unsafe.
Again, not saying it's not plausible with the non turbo brackets...but I doubt there is any danger with them, as MANY MANY MANY users have done this with the non turbo brackets, with out issue (and have now for years). I will say that the Turbo ones DO look very questionable though.
And for the 184194x, pad overhang is just that, pad overhang. Heck I've had some cars have overhang on OE repalcement stuff to the shop. Sure you loose some friction material, but it's not going to cause crash and die situations. Maybe some noise at most. In the case of these rear bracket upgrades, a few MM in over hang is nothing to loose any sleep over, especially for the gain in swept area on the larger rotor.
For Reference:
I will say this though (and this is an old saved file of mine) that there is most certainly a difference in caliper PN and rotor PN between the 84-86 and 87-89.
Carquest Part Numbers:
1984 300zx
Caliper: (84-86_ 17-687
Pads (84-88) RD272
Rotor:
31136 (84-85) PREMIUM - EXC CANADIAN MODELS - w/TURBO
3152 (84-86) PREMIUM - VEHICLES BUILT FOR CANADIAN MARKET
3256 (84-85) PREMIUM - EXC CANADIAN MODELS - w/o TURBO
1986 300zx
Caliper (84-86) 17-687
Pads (84-88) RD272
Rotor:
31136 (86) PREMIUM - EXC CANADIAN MODELS
1987 300zx
Caliper (87-89) 19-1221
Pads: (87-89) RD272
Rotor: (87-89) 31026
1989 300zx
Pads: (87-89) RD272
codyace on Thu Mar 15, 2012 9:56 pm, edited 1 time in total.
