elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Jan 30, 2007 5:52 pm
Yes thats right! GET STOKED! We're back!
This is to get you guys ready, details are being worked out but we are VERY close to getting all the details worked out...
Quantities available will be very limited, as Robert (the ECU programmer) only wants to do a couple a month. I have 3 lined up right now and they are basically ready to go.
I want to gauge interest, they are going to be a little more expensive.... Current pricing is going to be about $250 with a $100 core charge. I have to buy the core ECU's and we got burned a couple times before and im not letting it happen again.... We will send you an ECU ready to go, and you send us back a working ECU.. Trust me, im going to put this in my Q to be sure it works before I refund your money! You cannot send us an ECU and we reprogram it because we are doing this in runs, IE we do a few a month and then I sell them as the people want them.
i'm working out the details for those with active or TCS cars, however I think I should have a few ECU's for those cars in stock.... worst case scenario you have to wait a little longer but I can get those at some point....
So... who's in? Like I said, its looking like im only going to have 3 available in the near future, and very hit and miss after that
OTHER DETAILS: For those of you that dont know what the NICO ECU is or does, it is a reprogrammed stock ECU that gives you roughly 30HP gain... It eliminates your top speed limiter and raises RPM limit to 7400 RPM... it is a very noticeable upgrade... This ECU requires no other modifications, simply install the ECU into the car and instant 30HP, and installing the ECU is very simple.
Of course, you could just ask the over 50 other guys on this forum about how they liked the ECU!
You also get a 4 way switchable map with the ECU, which means you're basically getting 4 ECU's in one. With the flip of a switch, you can have our stage 2 program (which is even more powerful than JWT's tune AND its safer!), our BALLS OUT stage 3 program (which makes the car FLY), our patented "valet" program which limits the vehicle to 3000 RPM and 60MPH, or switch back to the stock ECU program.
The only qualifiers are you must have operational knock sensors or you will feel no difference. The ECU uses the knock sensors which is why we make more HP than JWT, while JWT's ECU does not use knock sensors. You must also run premium at all times!
So, who's in?
