https://www.nissanassist.com/campaigns/ ... uid-flush/
Nissan is conducting a Voluntary Service Campaign to flush the brake fluid, install new DOT 4 brake fluid, and inspect the Antilock Brake System (ABS) actuator on specific 2009 Nissan Murano vehicles. If the ABS actuator fails the inspection after the system has had the brake fluid flushed and upgraded, dealers will replace the ABS brake actuator. A new brake fluid cap with DOT 4 fluid specifications will be installed and an owner’s manual update will be provided to the customer.
