Bigdbonz80 »
https://forums.nicoclub.com/bigdbonz80-u75445.html
Wed Nov 21, 2007 7:16 am
Good Morning Gents and Happy Thanksgiving! I am a long time nissan pathfinder fan and have owned 2 pathfinders (93/95) and now a 2003 QX4. Just so you know where I'm coming from, I am pretty mechanically inclined, I installed the lift kits on both those pathfinders and did all my own mechanic work (brakes, suspension, engine work etc). I find myself stuck with what seems to be a common ALL MODE AWD problem and I'm posting this to see how many people with LE pathfinders or QX4s have this issue. I haven't driven an SE with the manual 4x4 shifter (no awd) so let me know what you guys think. Problem: ONLY from a dead start I get a vibration through the drivetrain at about 3500 (peak trq) then it goes away after 4000 rpm. It is only for that second I can feel that vibration and only from a stop when taking off hard. I can floor it on the highway or while moving and the truck is silk. If I put the QX in AWD or 4x4 it isnt as bad, which leads me to believe its the ALL MODE transfer case. I drove my best friends 2002 LE pathfinder and his does the same thing but he didn't notice it until I pointed it out. My other friend has an 02 QX4 and it also does the same thing?? I changed every single fluid in the truck (including diffs and transfer case) to full synthetic and had the transmission flushed out. Sullivan tire found a bad U joint and changed it, the problem is still there. I finally took it too infiniti and they said it was the rear bushings in the rear upper links, I changed those and nothing! Anybody think this is a stupid problem or what. You guys with your 3.5's let me know what you think, try taking off hard from a dead stop and tell me if you feel the same thing and I'll dismiss it as a nissan thing, I guess I'm just curious if the SE does it without ALL MODE? Thanks for hearing me out. Let me know what you think.
