Ive read and re-read multiple posts about the power valve screws issue on the VQ engines and am concerned and am planning to DIY to fix this issue. Hopefully, nothings happened and it will be a preventative thing. I do have low power and sluggish acceleration and am wondering if its got anything to do with anything as I cant figure it out. The acceleration is slightly better than my 00 Q with a 3.3 but still not as good as I expected and certainly not smooth as the 3.3. The 3.5 with 80k is rougher sounding and riding than the 3.3 with 126k. I have new air filter, oil filter, oil and everything looks ok.
Anyways, 1) I was wondering, does one need any special tools for this job or will my regular toolbox do? 2) Would you recommend this as a DIY for a novice? Ive only done oil changes and changed belts, plugs (on easier cars), put on an alternator and a radiator etc but nothing major so far. 3) Anything in particular that I should be careful about? Not unhooking a cable, or not reusing a gasket or a bolt , applying a sealant where applicable etc?
Ive printed out the excellent help from Bowtied(also a sticky at the top here)
http://npora.ipbhost.com//inde...17104
Ive also printed out the following pics here;http://davejohn.home.insightbb...x.htm#
I went to the Nissan dealership and they stated that in the last 15 yrs they have never heard of such an issue!! And then add that there was indeed a recall for this issue but only for the 04 and 05 Maximas and Altimas. They said theyd still do it for me but for 500 bucks!! I thanked them and left as I felt that that was just way too much.
I was wondering, is it the same labour and work involved in changing the spark plugs? If so, I know a good mechanic who could do it for a good price and while hes reached that point, maybe he could also loctite the power valve screws? Or would it need more work of unhooking, dismantling etc? I havent studied the prints yet and will be doing so today. Am planning to attempt this this week.
Also, does anyone have or could suggest where I could find the 02 QX4 FSM?
I am contemplating replacing the valve cover and replacing the PCV valve as well as I think I may be burning oil and there are no leaks and have read that this is due to yet another design flaw in that the baffles are poorly designed and some of the oil is sucked out through the PCV vavle.
Any help, advice and suggestions on the above would be greatly appreciated. Im a novice with only an aptitude towards this kind of work.
