Much thanks Xenon SE-R! I appreciate the attention. Feel free to also move this where ever, just be sure and let me know
Quick update:
Me being the self-made man that I am, I tore into this thing anyway...OMFGoodness! Contrary to popular belief, you don't have to remove the dash, instrument cluster, air bag, vents, etc., etc., etc. I now have experience with these particular items
however, this doesn't necessarily preclude the idea I know what I'm doing.
I have completely removed all A/C components for a thorough flush and inspection with the exception of the compressor and the low and high pressure lines that are attached to the compressor. Upon general inspection I have been unable to determine what may have caused the vacuum reading on the compound (low) side of the system. I will replace the expansion valve anyway as most of the information I've come across suggests this may be my culprit, along with deteriorating hose particulate clogging other areas of the system.
There is a larger tube (approximately 1.625 x 9.1875 read in inches) secured to the left (driver) side of the condensor with two smaller tubes leading from the left condensor manifold to the bottom of this tube. In the tubing port closest to the condensor manifold there appears to be a cylindrical screen filter (.375 x 2.375) with a cotton filter media of sorts in the end .675 of the tube (farthest away from the port end.) Around the outer area of the screen filter there appear to be pieces of rubber in varying sizes, not very large and more slivery than chuncky (pieces of hose as per my research? Me thinks so.) The total accumulation of this debris is not adequate to completely close off the ability of R134A to pass through the screen; I would say an apporximate restriction of perhaps 15-20%?
I applied light (20-30lbs) air pressure to the evaporator, condonsor, and all hoses (with the exception of the hoses attached to the compressor. I'm a little uncertain about trying to push anything through the compressor; don't want to damage same) with no apparent expulsion of debris, etc. There appears to be unrestricted air movement overall but, since I'm unsure of the routing of refrigerant through the fins in either the condensor or the evaporator, I am not too certain that any portion of the condensor or the evaporator may possibly have some amount of blockage.
I have purchased a flush agent (Dura II A/C Flush Solvent) for cleaning out the system. I am also thinking with the particular type of debris visibly present in what I'll call the system filter, it also appears as if I'll need to replace a hose(s) but I'm thinking one or the other (high or low) isn't available to the GP?
Anyway, what a deal! I'll continue on and keep this thread current. Thanks again Xenon SE-R and all others scoping out my situation. Hope to draw some good attention.
Have a Good 'un!
For the professional technicians: am I doing OK so far?
