Attaching Vert Door Panel Inserts to Door?
taweisse
Car: '93 240sx Vert
Hey everyone, I apologize if this has been covered already but I did try and search and didn't come up with what I'm looking for. All of my vert's tweed door panel inserts (except for the driver's) had begun to separate from the door panel, so I figured it was time to recover them anyway. I re-wrapped them in vinyl, and it turned out great, but I'm not sure how others have reattached them to the actual door panel. I know most screw it in, but I'd like to avoid that if possible. I was thinking epoxy all around the insert and staples to hold it while it dries, but figured I would ask before I commit to that. Thanks.
biggie
Had mine done by a interior place they stapled it. Looked great. I'd go with that if possible wasn't expensive.
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
Hi Temp Spray Glue. Get some for vinyl Landau roofs or headliners - made to stay up even when 150+ degrees.
taweisse
Car: '93 240sx Vert
blkvrtswp wrote:Hi Temp Spray Glue. Get some for vinyl Landau roofs or headliners - made to stay up even when 150+ degrees.
The spray glue for attaching the inserts to the door as well? That would be nice, as I already have the DAP Weldwood stuff from wrapping the vinyl.
blkvrtswp
DAP Weldwood is pretty much the best glue out there - I bought a gallon of it just to do the panels 'cause I couldn't find a smaller can! You should remove the vinyl that is left after pulling the tweed off.
Check out this link: https://broadfield.wordpress.com/2010/0 ... rd-insert/
94_240sx
Car: 94_240SX
This is your best bet. Not messy and secure.
Use this from the backside of the panel. Screw has to be short so it should go through the insert only the half way.
R3cKi
Car: 240SX convertible 1993 -
200SX RPS13 1991 -
any idea where to get this small stamples? only find ones with 10mm height. but oem got around 6mm
