trw2k wrote:What glue or adhesive should I use to reattach the Q45 onto the trunk?
I finished putting a spoiler on a few weeks ago and bought a new set for about $15 from Joe. The nice thing about a new set is they come mounted on clear plastic film that is cut to match the corner of the hood. Makes the placement and spacing very easy.
Short of buying a new set, I would go purchase some thin tacky tape from an auto parts store and trim it to fit the back of the numbers. It's probably the same tape that's used on the door strips (real thin, real sticky). It should be in an auto parts store but if not visit a local body shop and ask what they use. As narrow as you need to cut it I bet if you're nice they might give you the 2 square inches you need to reattach them. Good luck.
