mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Thu May 01, 2008 12:21 pm
Cliff notes: Should I hook up the wiring harness(es) to all the sensors, injectors, coils, etc BEFORE I drop my RB in, or wait until after I get it situated in the engine bay to mess with wiring? Seems like it would be alot easier to hook everything up beforehand while the engine is sitting on a pallet.
Story: Well my KA developed some knocking the other day, probably a rod bearing or something else internal -- I'm not going to bother repairing it. I'm now out a daily vehicle so I just want to get my RB finished up and swapped ASAP. After 2+ years of putting it together I'm really looking forward to finally hearing it run and abandoning my NRRBA brethren LOL. All that's left at this point is to run some vac hosing for the BOV and WG and figure out what I'm doing for a turbo drain, plus some misc bolts here and there. Once that stuff is wrapped up the motor can be dropped into my s13, custom downpipe/exhaust fabbed up and IC pipes modified...
I'm trying to get as much done before the swap as possible to make it easier down the road. I'm wondering if I should hook up the harness(es) to the motor ahead of time or wait until after I've got the motor swapped into the car? Right now all electrical harnesses are unhooked... Only vac, coolant and oil lines are connected. I pressure tested oil, coolant, fuel and intake systems and everything is air tight
