ATT. REVHARD OWNERS!
turbo2nr
Car: 97 240sx (kouki)
well im have problem with my revhard.
the damm studs keep walking back out causing the turbo to lift and cause a crazy exhasut leak. why? the nuts stay on but the whole studs come off.
i was driving hard last night and the studs came loose. i know alot of people just use bolts instead of a stud and nut.
anyone have a bolt size or know where i can get them?
thanks
nissanfanatic
Car: 1992 Nissan 240sx SE
I used bolts and never had a problem. Pull a stud, drive up to the hardware softly, and get a bolt of the same size..
You will have to cut one bolt to fit it in between the turbine housing and bolt hole.. I'm sure you know which one..
Florida240sx
I had a problem with my bolts coming out on my downpipe-turbo... After trying all kinds of gasket maker, threadlocker etc.... I ended up putting electrical tape on the threads then threading it in... No problems
Chezedik
Car: 1991 Nissan 240sx
Threadlocker will not work at those temps. Get yourself some knurled washers and bolts. Forget about spring loaded lock washers, the heat will flatten them.
WDRacing
Safety wire bolts...
DammitBobby
Car: S13 91 KA24DET
So far I am using the oven gasket stuff on the studs and 100 miles later no problems. I bought the studs, nuts and gasket maker from JGS. Good luck!
C-Kwik
TheRevhard uses the same threads as Nissan does for the mani to head studs. This means the Nuts for the mani to head studs will work. The Nissan nuts for this are mechanical locknuts. Serrated washers and the like never worked for me, but mechanical locknuts worked flawlessly and were reusable.
Just make sure the studs were tightened down properly using the doule-jam nut method and use mechanical locknuts and they should not come loose.
turbo2nr
thanks for all the responses. im glad im not the only one with teh problem
Chezedik:knurled washers and bolts? what do they look like and where can i get them?
WDRacing: safty wire bolts? same question what do they look like and where to get them. my professor was telling me to use this aswell, he said they used this on plane turbos so the bolts wont walk out..
DammitBobby: i called jgs and they said the bolts wont fit a revhard manifold? im confused..
C-Kwik: so if purchased 4 exhaust manifold studs i could use them in my revhard ?
thanks for the help
Chezedik
You should be able to find a knurled washer at any hardware supply store. Any stud that will screw in is the stud you need.
C-Kwik
turbo2nr wrote:C-Kwik: so if purchased 4 exhaust manifold studs i could use them in my revhard ?
I did....
C-Kwik
Chezedik wrote:You should be able to find a knurled washer at any hardware supply store. Any stud that will screw in is the stud you need.
I've used serrated washers before and while they took longer to back out, they still did.
Safety wire works well, but can be a pain in the butt on the turbine flange as space can be tight. You can also try Stage 8 locking hardware, but for the cost, mechanical locknuts will hold fine and are relatively easy to get as long as you're near a Nissan dealership.
WDRacing
Here's a great article, Safety Wire How To.
You can buy hardware such as nuts and bolts that are predrilled with safety wire holes. We safety wire EVERYTHING in the aviation bussiness.
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
wd what do you do in aviation? I am a mechanic on ea-6b prowlers. Used to work on ch-53e helicopters too. U millitary?
16-bit
Car: 1991 240sx, KA24DE
i got a tube of 2000 degree gasket maker that you're supposed to use for exhaust gaskets..
ill be sure to add a tad to each stud when i install on my top mount (bd)
C-Kwik
WDRacing wrote:Here's a great article, Safety Wire How To.
Safety wire can be a pain, but it is very effective. I had used safety wire for my wastegate as there was noway to use studs and a nut due to the configuration and locking bolts were cost prohibitive (cheap per unit, but I could only find it sold in bulk). But another tip about it is to use a drill to twist the wire. Stick the ends in the drill, tighen the chuck onto the wires and squeeze the trigger. This will make the wire twist easy, fast and consistent. Do be cautious not to overtighten though as you can snap the wire. Once it's tight, just clip off the excess and you're done...
Chezedik
WD, I think you are forgetting something. Little boys.... Queer.
turbo2nr
thanks alot
ive purchased m10 1.25 bolts 25mm those seem to fit the revhard well.
my plan is to use those + lock washers and lock tite and hope for the best.
i just have to cut down the front bolt so that it can fit in with the turbo, the clarence is tight.
any one have problems with this bolt staying in b/c its short?
