Very wrong. I had mine recirculated and it was quite audible. You won't hear it in many OEM turbo set-ups as the airbox is designed to decrease noise. But with an open element filter, you'll likely hear most BOV's even if they are recirculated. This is especially the case if the recirculation is not too far from the filter.Chezedik wrote:*no PSSST!!!!
Absolutely nothing if you can get it work riteJookmasta wrote:whats wrong with hearing the sound and showing people ur tailights.
Or for ppl who want minimal boost leak locations (2 added from recirc). Same reasoning for ppl who do blow thru (given they get the cobra maf and tune rite) - or map sensor. Popping an IC piping (which a lot of you guys have been through) isn't as dramatic if you have a blow-thru, given that the pipe, or in this case bov recirc hose, that popped is in front of the path.98s14inaz wrote:Atmospherically vented bov's are for ricers.
If exhausts can sound ricey... why can't bov's? touche!grimple1 wrote:Since when did the term "ricer" get applied to actual engine modifications? Tail lights, ok. Wheels, ok. Paint job, ok. BOV recirc or atmospherical, NO.
Sure put the MAF after the turbo, that way when your pipe pops off your turbo now has zero ability to produce boost. So the wastegate never opens, and it explodes the center section.brokeAs240sx wrote:Or for ppl who want minimal boost leak locations (2 added from recirc). Same reasoning for ppl who do blow thru (given they get the cobra maf and tune rite) - or map sensor. Popping an IC piping (which a lot of you guys have been through) isn't as dramatic if you have a blow-thru, given that the pipe, or in this case bov recirc hose, that popped is in front of the path.
That's a rather lame reason for going with open BOV. Done right, no pressurized hoses should ever come loose. This would be a band-aid and I'd equate that more with rice than the sound....brokeAs240sx wrote:Or for ppl who want minimal boost leak locations (2 added from recirc).
Well you certainly want a quality piece. What you don't need is one that is designed for high flow.Chezedik wrote:So then if I am going low boost and don't need to be super high performance, super-expensive is not necessary? Or is that conclusion premature?
i dont know if they seal any different but with my greddy type s my car would idle fine and stall apon revs. that valve cracked so now i have a 1g dsm valve and it wont even idle atmospheric i had to recirculate it. but its fine recirculated just a little quiet. i have a nice recirculations setup im gonna post pictures of sometime soon. everyone will like it.Chezedik wrote:What about OEMs versus aftermarket. I could get a 1g BOV for cheap, and if it will work just as well for my needs than I don't care. Do aftermarket valves seal any better?
I can't say for certain about the DSM valves, but some valves (I would suspect many OEM ones) actually are open when driving off-boost. This is to help reduce restriction and allow a more direct path for some of the air to divert around the turbo increasing gas mileage and response slightly. As boost is realized the valve shuts then opens when it sees the pressure differential required to open it again for an actual blow-off. It's possible the DSM valve you used may do this which could cause the symptoms you describe.get_up_mark wrote:i dont know if they seal any different but with my greddy type s my car would idle fine and stall apon revs. that valve cracked so now i have a 1g dsm valve and it wont even idle atmospheric i had to recirculate it. but its fine recirculated just a little quiet. i have a nice recirculations setup im gonna post pictures of sometime soon. everyone will like it.
It's hard for me to be as specific. I haven't used or experienced all the BOV's that are out there myself. I would try and get a general consensus through research to find out at least which ones to avoid.Chezedik wrote:To ask a stupid question: What is the difference. I would think if it were OEM, then it will be of high quality (all DSM cracks aside). By cheap you mean the SSAC parts on ebay, or something like that, or do you mean OEM as well.
you all and me drive rice bred cars, japan! ricer is just rice in bad taste!brokeAs240sx wrote:
The Greddy Type S on eBay are knockoffs? Is there a way to tell?Jookmasta wrote:well seeing as i build full boost within a 500 rpm increment, power is always waiting for me during, before, and after shifting lol. as stated earlier, run it whichever way gives u the best driveablity results. btw, i use a greddy type s (authentic, not ebay knockoff) and have had zero issues.
