ATF replace power steering fluid? :O
Fenvy
Car: 2005 350Z Base 6MT
I was at the meet the other day and someone said that they use ATF (automatic transmission fluid) so the power steering won't leak...
what do you guys think of this? is there any danger in doing this?
I asked because my power steering is leaking and it still leaks with new washer and clamp. How would I proceed about this?
Nismo_Freak
Car: 89 Nissan 240SX
ATF is power steering fluid pretty much...
PGBrian
it has been said that power steering fluid finds ways to leak out of teh system.
ATF is what nissan recommends to use for power steering system.i use it.you should use it.
w1ngzer0
Car: Pfft. i don't own a box
yah when i had my new rack i had them switch the p/s fluid to the red stuff. I didn't do it becuase people said to do it or are doing it. But because the FSM says to use ATF
