ATF Fluid
NI30
I have gone through past posts about what type of ATF to use for the I30 ATF. Would the Castrol Dexron III work as well as the Mobil 1?
PalmerWMD
Car: 2004 350Z
Yes,It will work just fine, but we like the MOBIL1 ATF better.
Fred...:)
Q451990
The Mobil 1 ATF should hold up longer and has a better additive package. It also tends to have better resistance to temperature extremes. Cheaper fluids under normal conditions just need to be replaced more often. The I30 transmission is fairly reliable, so I don't think you're making a huge mistake or anything... just the fact that you're replacing the fluid is a good thing!
Heath
