ATF Filter
m0nkeyprince
Car: 1998 Qx4
I am about to get a Wix transmission filter for my 1998 qx4, i am sure that it is 4 wheel drive, because it has the selector and low and hi range shifter, but when i looked at the '97 qx4 filter, it was the same part number as the filter that was meant for the 2WD. does the '97 qx4 not have 4WD? or when Wix says 4WD they mean a different system? I did not buy my qx4 from the dealership so i dont know the choices.
jhong1226
Car: 1999 Infiniti QX4 2011 Nissan Altima 2.5s
I think 2wd or 4wd uses the same filter for the transmission.
m0nkeyprince
Car: 1998 Qx4
filter yeaa, but i think its the gasket thats different? im not too suree though.. i could get a liquid gasket, but id rather go with the right rubber gasket.
frankh21
Car: 1999.5 Pathfinder
I just did mine and the guy at the counter recommended the rubber gasket vs the cork because the cork type had a tendency to leak. Also, don't over torque the pan bolts or you'll have leaks for sure.
01silvapathy
Car: 2001 Pathfinder LE 3.5
When I got my filter it came with 2 rubber gaskets, one which fit my trans pan (4wd) and a different looking one which I assume fits the 2wd.
