DannyChaos »
https://forums.nicoclub.com/dannychaos-u153462.html
Tue May 11, 2010 8:31 pm
The car:1991 240sx
The motor:Ka24de-twin cam
The problem:F'ed if I know but it ends up overheating.
Car has 130,000 on it and compression check shows 160ish across all four cyl.
About a year ago a new water pump and stat were installed due to the car running a bit hot.
Cooling problem was solved and the car was parked for about 6 months after that ,being started about every other week and run till stat opened than shut down.Car is now back on the road and has had a few new parts put in it.Parts are:clutch kit, tps,fuel filter,plugs/wires,oil change and cleaned maf.After the parts were installed I took her for a spin and all seemed on the up and up.Drove the car for a good 150miles through a 2 day span with no problems at all,stock temp gauge sitting at 1/4 and not going any higher.Now here is where shat gets tricky.I drove the car over the weekend for about 5 hours straight with no issues and than when I was pulling into a parking lot it decided to jump fast into the red about to overheat.I shut it down and popped the hood to find the coolant bubbling into the overflow,grabbed the upper hose it was red hot and hard,lower hose was piss warm and soft and while the temp gauge was climbing the heat coming through the vents was getting cooler and cooler. I let it sit until the heat dropped and the overflow dropped back down,popped the cap off and it was still full.I figured I had a bum stat and went n grabbed a new one and some coolant.I blew all the hoses out through the motor ,rad etc,every thing seemed to flow nice with no clumps or chunks of crap.Tossed the new stat in and filled her up,with the front end nice and jacked up burping out what I believed to be all the air in the system.I took the car for a test run and the problem seemed to go away.3 days of no cooling problems and than at random after a nice long drive it jumps way up again! I do the same thing again,figured I may have got a junk stat and swapped it out for another,flushed out the system again burped it again etc etc...Long and the short of it is this,the car will randomly overheat at no specific point of driving every now and than and I can not for the life of me find another case like this.You can leave the car idle for hours and it never gets above 1/4 the way up on the temp gauge "yes I understand that the stock gauge is crap and should not be trusted" You can drive the car hard,soft for 10 min or ten hours and it never has any issue.But the lower hose never seems to get hot ,just piss warm,the upper hose gets red hot and full,the heat works till the temp gauge goes up,Im not leaking or burning anything,I burped and bled the air out and still at random it overheats.I am at the point that I can not keep pulling all nighters trying to figure out what the hell is going on.If you guys have any ideas please feel free to throw um this way.Sorry for the long write up ,just wanted to make sure I gave a full run down so we are all on the same page.Thanks in advance
Dan
