qship96 wrote:plenum DOES NOT have to come off to reseal valve covers. are there any coolant leaks from rotton plenum hoses? If not, maybe consider just doing the valve cover gaskets now? If you are OK with the present power level,probably not worth doing the plenum if there are no leaky hoses. Valve cover reseal should run about 5-7 hours labor, minimal cost for gasket set, certainly replace spark plugs while doing gaskets as there should be zero extra labor charges to do so.
Yes, theres coolant loss so I gotta get it all done. But thanks for reminding me re: plugs, I'll add that to the shopping list.
Infinitiguy19 wrote:Give me say 2 weeks and I will come up there and help you. But you need to have a place to work for about a day. But ~$250 to do the plenum job alone? Does he know what he is getting into?
PM'd you. If I can work a space out, that'd be awesome. Just know that you're dealing with someone who is just a few hairs about novice at car repairs. But what I meant was he wanted the 25% markup on the kit in addition to labor.
maxnix wrote:Best bet would be to take your car to
Keith Vanmeter Auto Repair
(856) 415-2022
395 Wenonah Ave
Mantua, NJ 08051
5 and a half hour drive, unless the guy's got a bed for me to sleep on and/or he is way way cheap on labor I'll need some more persuading. I fear that that long of a jaunt may hurt the car even worse.
