Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Mon Sep 17, 2007 5:02 pm
If you have any DIY skills, then I suggest you do it yourself.It's not difficult.I've installed OEM fog lights on my 02 Pathfinder and my 06 Altima.I ordered the stuff as a kit. Fog lights, turn signal stalk, and in the case of my Pathfinder, a relay.I'm guessing that there is no kit yet for the 08 Coupe, but you should be able to order the lights and stalk at the parts counter.The car will be pre-wired, I'm 99% sure.You don't have to remove the steering wheel or anything. The only thing you remove is the top cover of the steering column. It's probably held in place by 3 phillips screws, access from the underside of the column. Then the top cover just pops off.The signal stalk can then be replaced in 30 seconds. Dead easy.As for the lights, each car is different. On my 06 Altima, I had to pull back the black plastic inner wheel well lining in order to get access to the back of the front bumper. My Pathfinder was easier. I could get access through the front.Like I said, if your handy in any way, then save your money and do it yourself.Good luck.
