AT Shifitng Noise - 2008 Frontier
clete purcel
thanks to all who replied.
Modified by clete purcel at 4:27 PM 4/1/2008
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Have you checked the fluid level yet? Sounds to me like something in the internals is too tight when cold and then expands once it heats up. That came out wrong but you know what I am getting at. :D
hsckris
Car: 07 V8 4runner
There is nothing wrong with the truck.
It should only do this when you first start out. It is the truck resetting the brakes. All frontiers with ABLS do it.
And if you are only at 1800rpm you ain't driving it right!
Rev_D21
It doesn't sound like he is describing the ABS acuator test that the truck performs when it first moves because he says it only does it once. The ABS tests each time the truck is started and moved.
hsckris
Car: 07 V8 4runner
Reverend D wrote:It doesn't sound like he is describing the ABS acuator test that the truck performs when it first moves because he says it only does it once. The ABS tests each time the truck is started and moved.
The abs does it is restarted and moved after a certain period of time.
He said:Quote »this ONLY happens the first time the truck shifts from 1st to 2nd[/quote]That is exactly what the ABLS system does.
Rev_D21
hsckris wrote:The abs does it is restarted and moved after a certain period of time.
He said:
Quote »It does not happen on any other shift, and it does not happen on the 1st to 2nd shift once the truck has been driven[/quote]So it only happens one time per day based on my understanding of his description.
hsckris
Car: 07 V8 4runner
Reverend D wrote:
Maybe he should just post what he means -- but looks to me like he is saying the only time it doesnt' happen is after it has been driven and not shut off -- exactly what the ABLS does. That, and what are the odds that a guy who doesn't even tach his truck over 1800rpm has another problem that resembles the ABLS this much.
Rev_D21
Yeh really, he should say what he means. 1800rpms at shift points is barely stepping on the gas.
