At my wit's end
ronkarr
Car: Nissan Maxima 2002
Hey, all. I have a 2002 Maxima, and my SES light came on. I took it to get it fixed, less than 2 weeks later it was on again. The shop I took it to said there was a recall on my car and to take it to a dealership and they should fix it for me.The dealer says no go, it isn't a recall problem. He said the wrong spark plugs were installed, so I take it back to the shop. They said they had never heard that before, but okay they will put the "correct" ones in. No dice the SES light still flashes. Anyone know what problem could be?
It usually happens when I first start the car it starts flashing, and the car runs real sluggish.
Also the dealer said he can input the car's VIN into a database to see if there is a recall on a car. Is that true?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Do you know what codes are reporting that are causing the CEL to illuminate? If the dealer or your mechanic can't tell you, most auto parts stores will tell you for free.
And yeah, the dealer is able to see what recalls are affecting your car by inputting the VIN into their database.
ronkarr
Well what the error code I got it: P0300. Is that what you are looking for?
What usually happens when I first start the car is that it is very sluggish, and lacks power. After I hit a stoplight or so it starts to run fine.
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
Random multiple misfire. Couple of things could cause it. Bad or low grade fuel, stopped up injectors, or coil packs. Nissan recommends replacement of all six coil packs if this code comes up.
ronkarr
Okay, thanks for the info.
ronkarr
Would the bad coils explain the problem being intermittent?
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
That sounds more likely to be a fuel issue.
ronkarr
I always put in the highest grade octane when I refuel. Hmmmm
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I believe Tibbs meant more along the lines of a fuel delivery issue. You may have bad injectors (one or many) or a problematic fuel pump.
ronkarr
Oh, okay. Thanks
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
Sorry for not being clear there sir. Thanks MoD.
