at FULL trottle it revs only 2000rpm what going on
racing_240sx
Car: 1993 nissan 240sx FASTback with a fully work head cams,milled,port,polish
1993 240sx ka24de auto trans. at full throttle it only revs a 2200rpm what going on my dad say that one cam jumped off timing. what wrong.or maybe it could be something not hooked up because i just changed the motor. can any body help ??????????????
TheOne
Car: 93 240sx FB
i think the computer just went into limp mode, usually happens because the MAF is bad.
usually thats what happens when the car wont rev past 2500rpm
racing_240sx
thanks alot
racing_240sx
racing_240sx
ok, but where do the timing mark supose to line up at on the pully ( the crank shaft one) on the little nobby thing about two inches above it
Henry G
Sounds like buying a FSM for your model car would really help you out.
racing_240sx
fsm what that mean ?
Chingon
Car: 1991 and 1992 hatchbacks
you probably disconnected your maf working on your car....
racing_240sx
no made sure that was plug in and i ran code that didn't even come up ot said it was fine
