at FULL throttle only revs at 2000 rpm
racing_240sx
Car: 1993 nissan 240sx FASTback with a fully work head cams,milled,port,polish
i just put a new used motor with 60,000 miles in my 1993 240sx it's a ka24de and i it's a auto trans. at full throttle it's only revs to about 2200 rpm, what the deal. my dad ws saying that he is pretty sure that one cam jumped off timming. could that be it. well because my timing mark the crank shaft pully dont line up to the ones on the engine when the #1 pistons is up on compression. well i hope some one can help or i have to take the motor back on warranty.
navysnail
do your basic diagnosis first, check the ECU for codes, make sure the maf, cas are all within spec, ect...
racing_240sx
what do you mean ( cas ) and can the codes detech cam timming
NISTECH
Crank angle sensor, its in the dist. You can also check your dist cap se if its made in italy if so toss it and get a new one preferably OEM
racing_240sx
who do you fix or adjust the CAS
NISTECH
you dont its not serviceable. But you dont know anthing is wrong with it yet.
racing_240sx
oh ok thanks alot
racing_240sx
ok, but where do the timing mark supose to line up at on the pully ( the crank shaft one) on the little nobby thing about two inches above it
racing_240sx
a litte help please my car only rev at 2200rpm i change the CAS now at start up it revs to 4000rpm with my foot on the gas but then die right down what wrong
NISTECH
what do you mean "it die right down" it stalls while your foots still on the gas or when you let off it dies?
racing_240sx
as i keep my foot on the gas it only revs bad to 2200 rpm it gots plenty of gas new injecters, good spark, new CAS, good MAF, every thing fine but dont rev
Touchdown038
Car: Computers, cars, sports
Clogged cat possibly?
racing_240sx
no, i figured it out my auto tranns is all messed internaly so i need another auto tranns
CDE
Car: 1989 240SX
I'm sorry, but I had to laugh out loud when I read your signature, racing_240SX.
I think what you ment to say was "Driving a Honda is like winning the special Olympics - Even if you win, you're still retarded"
