jhuman »
https://forums.nicoclub.com/jhuman-u121875.html
Tue May 26, 2015 5:37 am
After even more research, it appears that I have been confused. So my understanding is that the entire transmission system will hold about 9 quarts. However, if you simply drain the ATF pan, you will only get out about 4 quarts as most of the ATF is in the torque converter and lines. At this point, the posts I've read suggest doing 3 drain/refill cycles using 4 quarts for each cycle, and doing each drain/refill at about 20,000 mile intervals. The point of driving the car after doing a drain/refill is to get the new ATF circulating through the entire system and then performing the subsequent drain/refills to get the old stuff out. This is how I will proceed. I hope this will clarify doing the drain/refill method for others. Let me know if I've missed something.
