At a Glance: 2009 Infiniti FX35 / FX50
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
At a Glance: 2009 Infiniti FX50 and FX35
The all-new, second-generation Infiniti FX is a radical expression of sport and utility – offering exceptional levels of power, refinement and driving exhilaration. Created as a fusion of luxury, performance and SUV utility, with head-turning styling and an advanced sporty platform, the new FX is a showcase of Infiniti’s design and technology leadership.
Along with an aerodynamic, rigid yet lightweight body structure and sporty FM platform, the new FX features a extensive list of available equipment and technology designed to create an exhilarating and rewarding driving experience, including a choice of a new 390-horsepower 5.0-liter 32-valve DOHC V8 engine with VVEL (for Variable Valve Event & Lift) or 303-horsepower 3.5-liter 24-valve DOHC V6. Each engine is paired with a standard 7-speed automatic transmission featuring Adaptive Shift Control (ASC) and available solid magnesium paddle shifters. The new FX is also offered with available Intelligent All-Wheel Drive, double-wishbone front/multi-link rear suspension and large 4-wheel disc brakes, along with available Continuous Damping Control (CDC)®, Rear Active Steer, Intelligent Brake Assist and 21-inch super lightweight aluminum-alloy wheels designed by Enkei.
Inside, the new FX interior provides a warm, modern, inviting environment highlighted by a driver-oriented cockpit with intuitive controls, available sport seating and advanced audio, navigation and technology ranging from an 11-speaker Bose®-developed audio system to Infiniti Intelligent Key, available Intelligent Cruise Control (Full Speed Range) and available Around View Monitor system.
The new FX offers two industry-first safety technologies: Intelligent Brake Assist (IBA), which provides forward collision warning and automatic emergency braking; Distance Control Assist (DCA), which reduces the burden of driving in heavy traffic by intuitively helping to release the throttle and apply the brakes to maintain a safe distance from the vehicle ahead. Also available is a Lane Departure Warning/Lane Departure Prevention system, which helps keep the vehicle in its travel lane.
The all-new FX will be available in three models: FX50 AWD with 5.0-liter V8, FX35 AWD with 3.5-liter V6 and FX35 RWD with 3.5-liter V6. The new 2009 FX goes on sale at Infiniti dealers in the United States and Canada beginning in June 2008.
Highlights of the 2009 Infiniti FX include:
Body
* A fusion of luxury, performance and SUV utility, with short front and rear overhangs, low center of gravity, aggressive stance and available 21-inch wheels and tires * Polished, assertive styling, featuring a dark chrome grille, double wave hood, strong front-to-rear shoulder line, integrated rear spoiler, power sliding moonroof * Available Adaptive Front lighting System (AFS) * Standard High Intensity Discharge (HID) bi-functional projector headlights with automatic-on feature, integrated fog lights; aerodynamically designed rear LED taillights * New, distinctive functional side air vents, which reduce front end lift by five percent * Lightweight aluminum-alloy hood and doors * Chrome window moldings and door handles; available aluminum roof rails * Power folding, heated body-colored power adjustable outside sideview mirrors with puddle lamps and available reverse synchronization * Speed-sensitive windshield wipers with new aerodynamic flat blade wiper design, low-profile wiper arms; available rain-sensing function * Dual outlet exhaust with tailpipe finishers * Scratch Shield paint (self-healing clearcoat paint finish) * Offered in eight exterior colors * 0.35 coefficient of drag (FX35)
Engine, Driveline and Platform
* Front engine/rear-wheel drive (FX35 RWD) or all-wheel drive (FX50 AWD, FX35 AWD) * VK50VE 32-valve 5.0-liter DOHC V8 with advanced Variable Valve Event & Lift (VVEL) valve control technology, producing 390 horsepower and 369 lb-ft of torque (FX50) * VQ35HR 24-valve 3.5-liter DOHC V6, producing 303-horsepower and 262 lb-ft of torque (FX35) * New 7-speed electronically controlled automatic transmission with manual shift mode, Adaptive Shift Control (ASC) and Downshift Rev Matching * Available solid magnesium paddle shifters * ATTESA E-TS™ (Advanced Total Traction Engineering System for All Electronic Torque Split) AWD system (FX50 AWD, FX35 AWD) * Snow-Mode function (shifts throttle input algorithm in low-speed slippery road conditions once activated by driver for enhanced traction) * Built on Infiniti’s FM (Front Mid-ship) platform, specially designed and configured for use on FX * Front-to-rear weight distribution: FX50 AWD 54/46, FX35 AWD 53/47, FX35 RWD 52/48
Suspension, Steering and Braking
* Refined 4-wheel independent suspension with front double-wishbone and rear multi-link designs, extensive use of lightweight aluminum components, lightweight compact steel rear subframe * Dual Flow Path™ shock absorbers with rebound springs * Available Continuous Damping Control (CDC)® with driver-selectable “Auto” and “Sport” settings (FX50 Sport Package) * Large diameter front and rear stabilizer bars * Power-assisted twin-orifice vehicle-speed-sensitive rack-and-pinion steering * Available Rear Active Steer for increased responsiveness and handling (FX50 Sport Package) * 4-wheel power-assisted vented brakes; 4-wheel Anti-lock Braking System (ABS); Electronic Brake force Distribution (EBD); Brake Assist (BA), available Preview Braking * Aluminum-alloy 4-piston front/2-piston rear (opposed piston) calipers (FX50) * Available Intelligent Cruise Control (Full Speed Range) * Standard painted silver 18-inch split-5-spoke aluminum-alloy wheels with 265/60R18 all-season tires (FX35) * Available metallic finish 20-inch 5-spoke aluminum-alloy wheels with 265/50R20 all-season tires (FX35) * Super-lightweight 9.5Jx21 6-spoke aluminum-alloy wheels designed by Enkei with 265/45R21 all-season tires or available W-rated high-performance summer tires (FX50)
Interior Features
* Cockpit-like styling with standard leather-appointed seating * Available quilted leather-appointed seating * Personalized driver and passenger comfort zones with dual-zone front climate control HVAC system * Superior ingress and egress with low step-in height and easy-access seat height * Power-adjustable 10-way driver’s seat, available manual thigh support with power bolster adjustment * Available 2-Position Driver’s Memory Seat system (standard on FX50) * 8-way power-adjustable front passenger seat, available manual thigh support * Automatic driving position system – coordinates steering wheel and mirror position as seat is adjusted * Available climate-controlled heating and cooling front seats (standard FX50, optional FX35) * Three-spoke, perforated leather-wrapped, sport-style steering wheel with integrated cruise control and audio controls, available power tilt/telescope feature (standard on FX50) * Manually reclining 60/40 split-folding rear seat * 12-point sequential Welcome Lighting system * White/violet Fine Vision electroluminescent gauges * Standard 7.0-inch (FX35) or 8.0-inch (FX50) color information display * Signature Infiniti analog clock * Available aluminum pedals (standard FX50, optional FX35) * Genuine hand-stained Maple wood and piano black trim (standard on FX50, optional on FX35) * Advanced Climate Control System (ACCS) with Plasmacluster™ ionizer * Auto up/down front windows, available auto up/down rear windows * Infiniti Intelligent Key with Push Button Ignition * 11-speaker Bose® Premium audio system with 6-disc CD changer, Burr-Brown digital-to-analog converter (DAC), mp3-CD playback, auxiliary input jack and steering wheel audio controls * Infiniti Hard Drive (HDD) Navigation System with XM NavTraffic® with Real-Time Traffic Information (requires active XM® subscription, sold separately), 9.3GB Music Box Hard Drive with Interface System for iPod®, Compact Flash slot and Voice Recognition system * XM® Satellite Radio (requires active XM® subscription, sold separately) * Standard RearView Monitor * Available innovative Around View Monitor system with front, side and rear-mounted cameras to help reduce blind spots when parking * Available Bluetooth® Hands-Free Phone System (standard on FX50) * Available solid-construction cargo area cover, cargo net (standard on FX50) * Four 12-volt power points, dual front and rear cupholders, locking glove compartment * Available Infiniti DVD Mobile Entertainment System, 9.0-inch flip-down console-mounted rear monitor, DVD player mounted in front center console, two wireless headphones, remote control * Three available interior colors: Wheat, Graphite, Java
Safety and Security
* Available Intelligent Brake Assist (IBA) with Forward Collision Warning * Available Lane Departure Prevention (LDP) system * Available Distance Control Assist (DCA) * Infiniti Advanced Air Bag System (AABS) * Dual-stage front supplemental air bags with passenger seat occupant classification system and seat belt sensor * Seat-mounted side-impact air bags and roof-mounted curtain air bags for enhanced outboard seat occupant head protection * 3-point front seat belts with pre-tensioners and load limiters; ALR/ELR in all passenger seating positions (driver ELR only) * Available Pre-Crash Seat Belts * Seat belt reminder system (front) * Lower Anchors and Tethers for CHildren (LATCH) system in rear outboard seating positions, (upper tether for all rear seating positions) * Front-seat Active Head Restraints * Child safety rear door locks and power window lock-out button * Energy-absorbing steering column * Zone Body Construction with front and rear crumple zones * First aid kit and tool kit * Tire Pressure Monitoring System (TPMS) * Infiniti Vehicle Immobilizer System and Vehicle Security System * Vehicle Dynamic Control (VDC) with Traction Control System (TCS), cancel switch
hernandez5749
Car: '05 g35 coupe - some day with a ls swap
I'm dying to know if the engine mounts and transmission mount are the same as for the vq35.... i know the other engines go into that engine bay but curiousity is killing me. Would love to put that 5.0 into a g35 coupe!!!!! crazy huh?!?!?!?
Timmbo
hernandez5749 wrote:I'm dying to know if the engine mounts and transmission mount are the same as for the vq35.... i know the other engines go into that engine bay but curiousity is killing me. Would love to put that 5.0 into a g35 coupe!!!!! crazy huh?!?!?!?
Trust me, I wondered the same thing! That would be so sweet!!!!! A G50 coupe with a 7-speed and AWD!
hernandez5749
even if it wasn't AWD or a 7spd i would still want it!!!!!!!!!!!!!!! just give me a chance to have a g50 6spd n i'll be happy. Although a 7spd sounds really good especially since i love to take road trips all the time. I wouldn't have to use my second car (nissan pathfinder '00) cause i have 22's on it and that doesn't really workout for trips. Somebody, anybody has to come up with a way to do this. It would be criminal if they didn't!!!!!!!!!!!!
LONG LIVE THE G U SUKAS!!!!!!!!!!!!!!!
Ni55anpat
Car: 07 Z
I love the new FX...yum
08blackG35sedan
Car: 2008 G35 sedan
The new FX's interior is amazing.
BlckJCWGhst
Car: 05 Infiniti FX45 , 2009 Mini Cooper JCW
08blackG35sedan wrote:The new FX's interior is amazing.
Dibs On The Steering Wheel lol.... Im Going To see If The Infiniti DealerHere Will Install That New Steering Wheel On My 05
fxBeast
Car: Infiniti FX35 '06
I love everything about this new FX... But those ridiculous external "gills"!!!...I mean, ear rings are fine on people or even small to large animals, but cars shouldn't have non-functional bling accessories piercing their bodies.
I wonder if you can remove them?
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
