I hope the nickel and diming is worth it lol. So I can use a boost controller and NA ECU? Ill do some book learning and try to find all of the small stuff for the swap. Are you guys that have done the swap satisfied with it?twinturbozxtacy wrote:you can get a complete tt jdm for 1k... but all used motors are a shot in the dark. all these cars ever do is nickel and dime you... to the extreme ha ha. for a tt swap you need the ic piping, ic's, motor, fuel pump(u got already) motor mounts and trans with clutch. you can use a ebc with the stock na harness so the boost jets are no problem...i did mine for like 3k, but i had been well versed in the zx from my previous true tt car so i knew what i needed and so on.
Im pretty sure its USDM, but its an obd II engine.. I have a few other leads to chase to find a TT. Although a VH swap does look pretty enticing, now that there are pistons available and such. Ill keep trolling on craigslist for partoutsnissanfreak12 wrote:Extremely satisfied.
Yes you can use an NA ecu, you just need to get an EPROM with a chip, cost roughly 100-150 at most respected places. Its just a generic tune, but a lot of us do it with zero issues. 800 is a good price, but is it a JDM or USDM? How was the maintenance? Compression?
JDM's are a crap shoot, I got insanely lucky and mine is running great and at about 400 hp, great fun, enough power especially with the 4:10 gearing. If you plan on rebuilding, which is recommended, then you don't have much to worry about. If you want to find all you will need, Z1 performance has a nice list on doing the swap. Its time consuming, but really not extremely difficult. Personally I would loved to have put the VH45 in, but not too much n aftermarket support and wasn't happy with the choices I ran into when I was looking.
No, Bosch is not an acceptable plug to use in these engines.oerllikon wrote:Thanks for the replies guys. Ill check the injectors. I know with a TT swap there are a lot of nickel and dime expenses, but I found a long block TT motor with injectors, turbos, etc, IC piping with ICs for around 800. Does this seem like a good deal? I know the trannies minus the bellhousings are the same.. Is there anything else that would add up quickly to 5k? Where are the bulk of the expenses? Ill check the timing too, it does have a really bad chug, not like when a coil pack goes bad and it sounds like a sewing machine lol.
Again, thanks for the assistance
EDIT: The plugs were bosch platinums with 2 electrodes. Idk if these are acceptable or not? I know generally japanese cars are supposed to have NGKs
