nissanfreak12 wrote:What spark plugs did you use?
What injectors did you get? New or used? New or old style?
You sure the plugs are correctly on the injectors and coils?
Have you done a balance test?
Is your timing set correctly?
Don't give up on the car, they can be very finicky and pissy at times, but worth it in the end.
I got the injectors from shopinjectors.con. They are remans.
The plugs are the ngk. I got the ones that the fsm says to use.
Did a balance test this past weekend that resulted in finding 2 coils that were out. Replaced them and adjusted the iacv and the tps and now it holds an idle but has lost all power. I couldn't even pull it up my driveway.
The plan now is to replace the MAF with a known working n62 version and if that doesn't work, I will just pull the motor and rebuild it. I planned on rebuilding the motor eventually but wanted to get it running and driving for a while before I put her down for the winter.
Thanks for all the help. I'm not giving up. Just pissed that I made the rookie mistake of spending a s*** of money before truly diagnosing the car and it's issues.
