SgtOgre »
https://forums.nicoclub.com/sgtogre-u260457.html
Tue Jan 12, 2016 12:48 pm
Hey everyone, first post here. I have been a silent reader for a while and finally need some assistance. So thanks in advance for anything you can provide!
I have a 98 pathfinder that i bought about 8 months ago with 152k miles on it. It ran well but had that horrible death wobble. I researched the fix and found out it was the control arms. Ok, time to replace those. While i was under there i also replaced the shocks and struts for good measure. Cool, thats done.
Then i tackled the fact that the trim on the back 2 windows was old and leaking air. It made the cabin quite loud. I found some of those at a junk yard, worked great considering they are over $100 new. Cool, thats done.
Also replace brake booster, bled the brake system, replaced the air filter, oil change, changed the ATF fluid and filter, Replaced the battery, and replaced the lift supports on the back hatch and window. Cool, those are done.
I am almost ready to take it offroad, that is the end goal of this vehicle, camping and off roading. Now i need to buy some new tires, change the differential fluid, and change the transfer case fluid.
My questions start here:
1. Any advice on tires? I have no lift and currently have 235/75r15's on there, but i want to go as big as possible without a lift. I have heard 31s are possible but i was wondering if anyone had some advice on that. I do want some All Terrain tires for sure.
2. Is there anything i need to grease with a grease gun? I have heard the driveshaft needs it, where is that located and are there any other places that need it?
3. I am going to change the read differential fluid (i have a limited slip diff YAY) do i also need to change the front? Is it the same process? And any advice on the transfer case fluid change?
I guess that about it. Sorry about the long post, just eager to get this thing in the MUD!
