sschantz wrote:Apologies guys, guess I should proof read more often... Scratches are on Inside of the door on the plastic ......
Yrs ago there was a product called Black Chrome for bumpers, plastic etc that would have worked great but unfort it is no longer made..
Actually Black Chome was not much more than a reformulation of Armour All. Both will hide fine scratches in plastic but neither will do much for fixing gouges or areas where the grain of the plastic has been abraded. Any products you have that were made for cleaning and/or polishing your dash should work to make the door scratch less noticeable. The closest thing to Black Chrome still on the market would be 271 Duragloss
Aerospace Protectant 303 is an excellent product (my personal favorite) for treating the plastic surfaces inside your car and will also hide fine scratches. Problem is its not cheap and is usually only found in boating / marine supply stores. Another good plastic polish (removes "fine" scratches is Plexus... I use it to "remove" (polish out) fine scratches and swirl marks from the my clear bra on my Rogue but its also expensive and hard to find locally (I order mine off the Internet).
That said the plastic panels panels inside the Rogue (and most cars) are not very durable when it comes to scratches. You could bend a plastic door panel in half without it breaking but can scratch with any hard surface (including another piece of plastic).
Modified by Elton Noway at 1:42 AM 11/25/2009
