ASP vs. Unorthodox Racing Pully
240SXer
Car: 1995 240sx SE (2jz powered)
Hello. I'm gonna be getting an Injen CAI and one of these pullys. I'm not quite sure which one is the best to get. Any suggestions? From what I can understand they do the same thing. One (the UA) is 190 and the other is 120. What's the difference? Is the UA worth the difference in price? I'm not gonna get the full UA kit, it's a rip. I'm just going to get the crank if I get anything from UA.
Thanks,
David.
bj180sx
Car: cars
the aps is a little bigger than the unorthodox so people that worry about their a/c and other stuff should prob get the asp. Really not much difference in them.
240SXer
So they're both good? I'll get the ASP. Does anyone know what kinda gain is to be expected?
daniel240
Car: cars/motocross
rpm outlet has the asp pulley for $99. just thought you would like to know. i got mine from there.
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
What makes the Unorthodox kit a rip off? I would think it would be better to replace all the pullies instead of just the crank. Just curious.
240SXer
Well.. Not totally a rip off. More like not worth it. I just dont think the 400+ price tag is worth the gain you'd get. At least versuses the single crankshaft pully. If it were cheaper ya i'd change em all, but it's just too expencive. I doubt you'd get that much more power than with the single. Correct me if i'm wrong...
David.
240SXer
daniel240 wrote:rpm outlet has the asp pulley for $99. just thought you would like to know. i got mine from there.
Did you get a good gain?
David.
Kinesthesia
For the record... I called ASP and compared to UR's website.
Stock Crank Pulley Weight: 6 lbs 10 ozASP 2 lb 4 ozUR 1 lb 11.1 oz
Some more comparison info: Gates Belt sizesASP Belt Guide Alt. K040292, Fan, p/s. K030384, A/C Stock
UR Belt Guide Alt K040285Air Conditioning - K040345 Power Steering - Remains the same for most years, otherwise use Gates K030380
It appears as though ASP does not underdrive the A/C which seems like a good idea, since you can turn it off. And UR doesn't underdrive the power steering, I guess because not much is more important than being able to steer !
I'm still debating back and forth myself...
