Asking for all opinions on the following wheel/tire size combo
1992Q45A
I know I posted this before, but I wanted it to be obvious.
What is everyones opinion on the following wheel/tire size on a Q45A
If the tires don't sound like a match, how about the wheels on different tire size? What would the best tire size be, do you think. Based on others choices it looks like a 255/40/18.. Agree/disagree?
Wheel info (read off wheel)OZMade in Italy8 1/2 Jx18 H2C=180ET20G05001362 051As-7 LP
97Q45t
Car: Viper RT/10, Ford Explorer 4WD
I don't have any recommendation for the overall diameter (sidewall) because I don't know the diameter of a G50 stock size tire. However, the 245 and 255 width would look PERFECT on an 8.5" width rim. I have 245 and 275 go on both front and rear 9" width rims. I'd wish that I had 8.5" for the 245 and 9.5" for the 275.
1992Q45A
Thanks!
Your carputer was the motivation for me, to start my project
OEM diameter is 26.1".
Ryan, 255/40/18 is (IMO) perfect for the Q. I have 245/40/18, and if they had HAD 255's in stock, I would have gotten them.
Good choice.
szh
Car: 2018 Tesla Model 3.
1. Another tire size possibiltity is 245/45-18.
2. The offset of 20mm (that I would interpret the "ET20" as) bothers me. This is low and may cause a fitment problem. Grant of TireRack (try the Tires, Wheels, forum here on NICO) may know more ...
Z
1992Q45A
Great, and thanks
I'll use and abuse the existing 265s and go with some 255s
PalmerWMD
Car: 2004 350Z
I disagree with some of the assembled gentlemen.
While my rear tires (the 18's) are a bit wider than your (9.0 I think) in my expereince 255 is simply too wide.
The car follows ruts way too willingly in 255's its almost disconcerting .Also the 245/40-18's are a closer match to stock tire diameter.
Fred...
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
I have 245/45/18's on my stock o4 Maxima wheels.
I haven't put a wheel caliper on them, but I *think* they're 8.0. They might be 8.5.
They're really tall compared to stock, like a little ov er 1/2" I believe, but fill the wells nicely & don't scrub.
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
Dicount tire Direct has a very good tire size calculator.
http://www.discounttiredirect....h.jsp
Check it out yourself, but the closest match looks like the 245/45/18. I didn't check load ratings so you should check. Hope that helps.
louiegz
Sorry 255/40/18. My bad. Man! Your going to feel every bump. With the pot holes here in Jersey, I'd kill those rims.
1992Q45A
Luckily AZ has smooth roads
1qckser
Car: my wife, daughter, q45T,G20T,SE-R
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I have 255/45/17 on the silver car. I like them, and am currently putting on 2 new rears.
I have had the 245/45/17, 235/45/17, and 225/50/17 on the car. All on 8" rims.
I like the 255 size the best. Softer ride than the 235 & 245, and better wet handling than the 225/50. They are alos 26.1", which is spot-on.
The Sumitomo HTR+ are good tires, but get noisy later in life. The NITTO NT455 are good looking, great in water, but get REAL noisy later in life, and have balancing problems. Jimmy is putting on Fusion tires, today. We will see what they do, over the next few months.
I was going with teh Kuhmo's, but they were not in stock.
The black car still has the 15" x 6.5" BBS wheels, wit 215/65/15 Yokohama's. That car is a LOT softer and a LOT quieter.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
I'm with Jeff, 255/45-17 been berry, berry good to me.
