JustDriftMore wrote:hey your making progress... which is more than i can say for some of the people in here
i know right, look at all this useless crap i've been buying with my money in all the 18 months i've had it and been working on it. i should've been saving for paint and fixing my gaps?!
OUT DATED MOD LIST:
EXTERIORziptiesstickersunknown trunk lipbomex type I mirrorssexy earringsR.E amemyia replica rear diffuserH4 clear headlights w/ 7 color ledsclear zenki bumper lightsCF front +20mm vented fendersfiberglass rear +30mm overfendersd3s rear HID reverse lightcrispy oem tails
ENGINEremoved acapexi turbo timerwalbro 255 fuel pumpgreddy type s bovgreddy o2 elbow w/ 3in outlet and o2 sensorobx 3in straight through downpipe including cat section5zigen ProRacer GN+ replica mufflerkoyo high performance radiatorgeneric intake filteraltima dual electric fansturbosmart manual boost controllergreddy profec b spec 2 electronic boost controllergreddy oil cacth canapex'i SAFC 2renova cf cooling panelMR bottom mount turbo maniexhaust wrapduct tape550cc top feed injectorsARP headstudsnissan oem o-ringsnissan oem valve cover gasket300ZX N62 MAFGReddy rocker arm stoppersGReddy Airinx intakeGReddy oil filter relocatorhaltech e6k standalone ecu with flying lead harness, manual and diskmsd dis-4 high output cdi ignitionmsd ign coils (4) with custom brackets/wiring4x 720cc msd injectorsgm 3 bar map sensoriat sensorfreddy intake manifold professionally powdercoatedSR valve cover professionally powdercoatedcxracing fmic and pipesGReddy cold pipe for GReddy intake manifold7 layer OEM S15 exhaust gasketCircuit Sports turbo lines
WHEELSkosei k1 16x7.5 +32et w/ kuhmo ecsta 712 215/55/16 tires225/45 kuhmo ast (2)255/40 azenis rt-615 (2)5zigen FN01R-C 17x10 et +12 (2) professionally powdercoated5zigen FN01R-C 17x9 et +15 (2) professionally powdercoated
SUSPENSIONmoog ball jointsVLSDS14 FLCAsfront and rear s14 5 lug hubsfront and rear strut tower barsMR rear upper control armsMR tension armsMR tie rodsMR traction rods10mm spacerskyb agx on sportlines springsstance GR+ coilovershubcentric aluminum ringsproject kics lug nutsnismo extended studs
INTERIORserial cable to connect haltech to laptopbattery relocationguttedDOHC HUD clusterautometer boost gaugenismo shift knobauthentic camo shift boot from soldier ragpilot racing wheelsteering wheel hubgeneric quick releaseneukin 6 button switch panelwink 5 panel mirrorgreen ignition key ring lightsparco pro2000 racing bucketsparco 3pt harnesssparco sliders on generic bracketscarbon fibresque pass seat
BRAKEScross drilled/slotted rotors300ZX 17/16 brake master cylMR BMC heatshield30mm 300ZX rotors/alum calipers/e-brake and rear conversion lines
