dinovio wrote: Can I just switch one of them out, If I can do this please tell me how to get that light out if the front console, I tried and I thought I was going to bust it up
If you're asking about the connector for the light that is part of the ashtray assembly then, yes, it is a bear to get that connector loose. There is a small plastic tab on that connector that either has to be squeezed or lifted before it will disconnect. Once you've released the tab, grip the connector top and bottom with a pair of needle nose pliers and pull straight out.
Be careful handling the ashtray assembly. The two tabs that attach it to the center console are delicate. If either breaks it's unusable. And yes, the lighter sockets are interchangeable front to rear.
