ASE664 Air\Active Suspension Conroller
GreenQ45a
Car: 2012 Altima 3.5 SR CVT - Dark Slate w\Black Leather Sport\Tech\Premium
2010 Pathfinder 4.0 SE Auto - Red w\Grey Cloth Towing Pkg\Tech 1
Here is its list of features: (translated from JP)
Left and right balance adjustment function
Balance of height left and right error can be adjusted simply.
Super LOW mode
Super LOW mode loading which actualizes the ultimate LOWDOWN. Already, the above this the LOW forum which cannot be desired is actualized.
Digital speedometer indicatory function
0 - Speed to the 300km/h can be indicated.
Approximately independence car elevation fixed
As for air suspension in height front and back independence 16 stages in +L setting possibility. As for active car 8 stages +L. Height span of adjustable range: Air suspension +40mm - -95mm / the active suspension +10mm - -50mm (the Y33 seaming machine approximately -20mm).
Normal return function
It can return to the normal height simply at switches 1.
Triple height memory function
Beforehand including normal, three memories height by doing, height of 4 sorts Being one-touch, it is changed.
Vehicle speed response height control function
It is possible to change automatically, according to the vehicle speed which sets the height of 2 sorts which it sets, optionally.
Dynamic control
The micro-computer instantaneously analyzes & judges the height data which is sent from the height sensor, selects the optimum data and converts. As control error such as rowlock * high lock is prevented beforehand, burden is not applied on either the air suspension computer
A/D input correspondence advanced CPU micro-computer loading
You adopt the new model advanced one tip/chip micro-computer of the A/D converter built-in which was developed in exclusive use to the height control control section which is the heart. The powerful noise filter and the input protection network which shut out unnecessary noise were adopted to the input section of the height data, high function the height control which is stabilized was actualized.
This was found here ... its been the most helpful trying to figure this thing out. " TARGET="_blank">http://translate.google.com/tr...ls
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Good information Green!!!
Can the ride stiffness be changed at all??? Just looks like this is for height control...
Itd be cool to be able to just hike the car way up to do oil changes instead of jacking it up
