ASCD compatibility question
jamesblonde82
Car: 1992 Nissan 240SX convertible RIP 5/10/07
1993 Nissan 240SX convertible
i need to know what ASCD control units are compatible with what year, and if auto or manual matters. this is the cruise control computer that sits behind the ECU in the passenger kick panel.
what years will work with my automatic 92 KA24de?will a manual transmission one work with my auto?
jamesblonde82
bump
Kraelic
Car: 89 240sx
I have seen that an 89 uses a 16 pin connector on the unit, and a 91 uses an 18 pin connector. I would guess 89 and 90 are the same between years and the 91 to 94 are the same between years, I have not looked at the 95 to 98 s14
According to the wiring schematics I have seen, auto and manual uses the same control box it just runs through the clutch switch or an automatic switch to cancel cruise in neutral or park.
