TX240SX »
https://forums.nicoclub.com/tx240sx-u2971.html
Wed Nov 27, 2002 10:54 pm
Do you have an automatic? You may want to check your cooling lines. Hopefully you popped a line and the loss of fluid shut your trans down. Other than that you may have smoked the clutches. You need to get under the car and find where the fluid is coming from. Hopefully you just need to replace a line and fill the trans. Good luck. If your car is a 5spd. Check the slave cylinder. It could explain the leak and the clutch not working.
