As requested few pics of the G-unit
BlackBirdVQ
Car: 93 G20, 94 Q45, 00 Altima, 01 Maxima- quite a few
pic of the engine coming out.... sitting amongst all kinds of SR20 parts- like the crankshaft behind it.
BlackBirdVQ
pic of the 1st DET going into the car- U12 BBird unit with a top mount interheater (cooler)
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
not bad keep us informed.
BlackBirdVQ
engine installed.... too bad it had rod knock and I got full refund for it from SOKO. They actually let me keep everything but the long block for all the trouble I went through. I need the car to run the same weekend I picked up the motor from them, as my brother needed something to drive.
I guess if I took the time to check the bearings, it would have been avoided.. but I got a newer motor out of the deal.
BlackBirdVQ
Pulled the old engine out and put this in....
BlackBirdVQ
Much nicer engine, supper clean inside- I didn't bother removing the oil pans to check the bearings out. Removing a SR20 is like a hour ordeal anyways, having done so many of them I can do it with my eyes closed...
BlackBirdVQ
At the same time I installed a FMIC, which the 1st DET would have gotten later on, but since the Avenir motor I got was set up for FMIC setup and came with no intercooler, I had to imrovise and get it all done at the time of the swap.
I bought the car on Ebay for 800 bux with a Rod knock, everything else was in good condition.
BlackBirdVQ
Few interior shots here, I got the car detailed at my work by my porters so it looked showroom clean inside out- check out the leather !
BlackBirdVQ
Idleing away at the gas station.... S-AFCII mounted in the position where its not seen to the eye, notice the old school Blitz boost gauge- 90mm unit I had on my SE-R since 98.
BlackBirdVQ
Few pics of the 2nd turbo setup I installed on the car....
BlackBirdVQ
more pics of this huge setup, custom equal lenght manifold, T4 turbo, TiAL WG, HKS ByPass, 740cc injectors, Z32 blow thru MAF, side exit exhaust, NISMO FPR.
BlackBirdVQ
Very unstreetable on the stock wheels and some cheezy tires the car came with... I have some 17" BBS that I need to install, in these pics you can see the car is sitting on KYB AGX and S-tech springs. Notice all the dust on the wheels- OEM brakes on some cheap pads.... can't stop well from 160+MPH that well.
Well thats all, no dynocharts to post as I can't find them at the moment, but rest assured it spun tires at 90MPH in 4th gear with noooo problem
norikumiin
mmm...gorgeous...clean swap and lots of power. I can't wait to see what else you do with it
