ARP stud question
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
So I hand tightened all the studs into the block. Afterwards i noticed that the front left stud (staring at the engine) sticks up abt 1/4" or so above the rest of the studs. anybody else have this problem? They are the correct studs and it went in with no problems at all.
float_6969
Yup, it's known that happens. The threads aren't as deep as over there because of the coolant port.
What I did on mine, just to be safe, was use all of the stock washers PLUS the ARP washers. No problems so far, and it's been like that for 5 years now.
sjbsuperman1425
CA18DET
did u just use the stock washer on that stud or all the studs? atleast i know im not messing it up lol
float_6969
I used both washers on all of the studs.
KEMP
Car: 1990 240sx CA18DET
float_6969 wrote:I used both washers on all of the studs.
i have had no problems on leaks on that part of the motor with using just the arp washers, i noticed it too, and just did as arp said, and had no problems until some other stuff happened
sjbsuperman1425
CA18DET
if i have the stock washers i'll use those along with the ARP washers, but im not 100% i still have them all.
Thanks RyanThanks KEMP
