arp part number
gani
Car: cars what else
need the part numbers for the arp headstud kit. did a search and cant find. pliz anyone????????
biosehnsucht
same as SR Main Stud kit, need an extra washer on the bolt over the thermostat housing. we did mine with double'd up washers on all bolts cause it was nearly bottomed out to begin with on the normal ones...
cuzan0
ARP Part# of 202-5402 which is the part number for the SR20DET Main Stud Kit will work.i know this cause i am using them in my running motor and there is no need to double up on washers....just be sure to use a thin 12 point 12mm socket or else the socket won't fit to tighten the stud nuts
