nismo dreaming »
https://forums.nicoclub.com/nismo-dreaming-u34698.html
Fri Aug 08, 2008 7:17 pm
hi, i got a 97 ka24de that am rebuilding, and i have both arp head & mains studs, now the problem is that the main studs, they're all the same lenght(i got'em from frsport part # 202-5401) when there is supposed to be 3 longer studs and 7 regular size studs.
i'd like to get the engine done asap, so my question is could i use the stock 3 long bolts?or should i just go ahead and order the other 3 studs(aparently you can get just the 3 from arp)
another thing that i though is could i just unscrew the 3 studs further up?(enough to where it shows the stud and i can put the nut through), this would just seem a really bad idea but for the other studs when you hand tighten them, you are supposed to rotate'em back 1/4 or more so that when you torque'em, it'll seat right.
i plan on running a max of 600rwhp or so. i've never heard of anyone breaking stock studs.
