Arp main stud
Funktown240
Car: 93' 240sx
I installed some main studs following the instructions that came with it but now am having problems starting the motor. Im pretty sure that I torqued them to 75 or 80 ft/lbs in stages with moly lube. I was checking other sites and said to torque to 55 ft/lbs. Double checked the timing and alternator belt tension to make sure that they werent too tight. Motor isnt cranking fast enough to start and am wondering if the main studs are holding the crank too tight. :mad:
RRRRB
Car: 98 RB powered S14
Try rolling it over by hand. see what it feel like.
You should ALWAYS have the main line checked. Its a must when using different fasteners.
Why did you use ARP when people make 1000 horsepower on stock bolts?
Funktown240
Car: 93' 240sx
Takes a little muscle to turn the crank by hand, I replaced the factory bolts because they got overtorqued.
ben h
Car: 90 240sx with ls1/t56
when swaping to arp and going over stock torque settings u need to get it line bored check ur clearences at them torque settings will proly be way to tight and i would try and crank over id pull off the pan pull them apart and see if it still looks ok
