ty i went that route last nite.....now if i can only get the main timing gear back on i can wrap this upeazye2000 wrote:Well, hopefully this will get you started... Good luck!
http://www.jgsturbo.com/arptrq.html
YES--you do not use the factor torques when you use the supplied lubricant with your arp studs.bruinbear714 wrote:Use the torque specs that comes with the instruction, along with their lubricant.
the web site didnt show anything useful, so i went the jgs routerotorimp wrote:
It is all about friction--do some reading on the ARP website!!!!
