arp head studs lenght? (pic)
godrifttoday
hey just bought some arp head studs but they are all the same length i got all 10, arent the head studs supposto have 2 studs with different size? did by any chance get the wrong set?
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
godrifttoday wrote:hey just bought some arp head studs but they are all the same length i got all 10, arent the head studs supposto have 2 studs with different size? did by any chance get the wrong set?
I don't know if those are the right ones. Please specify if it is for the KA24de or the KA24e.
Modified by Bigvinnie at 10:55 PM 8/24/2009
godrifttoday
ka24de
Bigvinnie
Basically if you compare the ARP head studs, to the OEM bolt they should just be a little longer than 100mm in length, (I would think 110mm for the nut and washer).Stock bolts are 100mm as well. So if the studs are a little longer than they are suppose to check the thread depth you should have atleast 25mm or better of depth at both ends in order for it to work.
You ordered studs, there is also a head bolt kit as well. I don't know if that is what is causing the confusion.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
i think your confused with the main stud set..the head studs are all the same length..the main studs come with 2 longer studs for the high area on the main girdle...the main studs are a combination of saturn head studs and opel head studs..but hay..it works...enjoy your new found clamping power..and good luck to ya.
