arp head stud installation
quiksilvia
Car: 95 s14 se
hey this is quik's friend on his name he's on the pohne wit me and needs some help.... he says" how do you instal arp head studs in a red top and what are the torque specs???"
solaris22
check the FSM it's in there, however I believe the ARP bolts require their own torque setting, I could be wrong
quiksilvia
Car: 95 s14 se
well geez solaris, u should get a medal for u fine work, i figured it out
RobDET
Car: Cars
i know in a V8 when you install head studs you thred them in till they bottom out and then you unthread them just a little (like 1/4 turn) I'm not sure why you do this but my friend used to work at the most reputable machine shop in the area and thats how they did it.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Quote »i know in a V8 when you install head studs you thred them in till they bottom out and then you unthread them just a little (like 1/4 turn) I'm not sure why you do this but my friend used to work at the most reputable machine shop in the area and thats how they did it.[/quote]
Yep this is how you do it, you lube it with the supplied moly lube and thread them in by hand. When it bottoms out, back it out a little. Then put the head on and lube the washers and nuts on. ARP recommends 65lbs of torque if you use their lube on aluminum heads, but I was kinda iffy on that and went ahead and did 75-80lbs.
quiksilvia
Car: 95 s14 se
i might have ur ps bracket genx-aim me.
