ARP FLywheel bolt question!
mikecef2
Car: 90' Nissan 240sx (SR20det)
Ok So I bought arp flywheel bolts for the sr20 and when I opened the package and read the instructions it says to use the ultra torque fastener lubricant and torque to 49 ft.lbs or using 30W oil, torque to 64 ft.lbs. The stock bolts were put in with 101 ft.lbs and used with thread locker. What do I torque these bolts to? I have the lubricant from ARP so I'd like to use it although only using half of the recommended oem torque scares the ISH outta me. Anyone shed some light?
mikecef2
So for anyone who gets these and doesn't know what to do here is the explanation ballerbolts.com gave me. They said to put thread locker or the arp lube on the first 4 threads of the bolt and the rest of the threads and under the head of the bolt with 30 weight oil. Then torque the bolts to 64 ft.lbs because they are not torque to yield or " throw away after torqueing" bolts. Hope this helps the nico community!
