Around View Monitor
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
nickezh
Car: Ex35
Hello,i'm having a problem with the display monitori mean that in the bird eye view, i cant see my car :S there is a grey square instead of the vehicule image, with a yellow cross on the frontall cameras 4 cameras are working. I started having this problem after changing my front bumper. Help me
Thanks in advance.
cjre1
Car: Infiniti EX35 Journey
Check the wiring in the front, when you changed your bumper, something happened. The front camera is the main camera for the system. This one works first, is what I believe.
All the cameras need to work before the system works. I think that they are in a series circuit. Don't quote me on this, I did not research this completely yet.
Maybe someone else has more inout or experience.
nickezh
Car: Ex35
i will try to check the wiring...thanks for the post
cjre1
You are welcome. I hope that you didn't damage the camera. Also, follow the wires back to the engine compartment, you might of pulled it out of the socket. Check the fuse to.
Take care.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Welcome to Nico.
That is an indication that your AVM is out of calibration. You need to take it to an Infiniti dealer and have them recalibrate it.
If you have no access to this and want to try this let me know and I will try to help you as much as possible.
nickezh
Car: Ex35
I took it to an infinity dealer this morning...they solved the problem in 10 minutes. He said it was a problem in the system :Sbut now everything is fine, i can enjoy my bird eye view with no problem.
anyways thanks for the support
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
