Caster LF 4.2 RF 4.4Camber LF -1.4 RF -1.8Toe LF .05 RF .0599q45t_vl wrote:Can you post the numbers?
Camber LR -1.3 RR -1.3Toe LR .10 RR .30
thrust angle .2 deg.Q45tech wrote:What is thrust angle?
The front camber needs to be - 0.75 [+-0.2] [with you in driverseat] to avoid excessive inside tire wear and diminished braking performance.
The closer you get to perfect the more noticeable the least road imperfections will be.
UPDATE:Lowered pressure all around 35.5 front and 35 rear - equalizing and lowering pressure seems to have alieviated 90% of my problem.jamesmost wrote:just checked and adjusted pressure was a bit off had 37 lbs both rear and LF 36 RF 38adjusted to 35lbs rear and 35.5 lbs frontAvon M550
245/45 WR17 95W 360 AA A road surface varied should itry less pressure??
Modified by jamesmost at 10:44 AM 3/6/2006
Jeff have not gone thru a set of tires w/ the adjustable arms yet - befor the adj. were on my tires would be wasted on the inside w/ 1/3 tred left on the tireJeff Williams wrote:I bet you wear the heck out of the front inside tires with that negative camber. Get it closer to -1, and this will help. I also had my toe-in adjusted to zero. This helped a lot with the tracking.
I believed this once also, early in the days of radial tire technology. Actually, this is a mistake, because it does not allow for the thrust load of forward travel.Jeff Williams wrote: I also had my toe-in adjusted to zero. This helped a lot with the tracking.
Is Caster adjustable?? if not what is bent ?? or is that from lowering springs??qship96 wrote:
caster is way off!
Some reference to possible "bent" mounting points in this thread.jamesmost wrote:Is Caster adjustable?? if not what is bent ?? or is that from lowering springs??
