armrest for 1.8 sedan 09
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
langkimvo
Car: 2009 nissan versa sedan s/sl
a must have from ebay. $48. took 21 days to get and well worth it.
JHR16DE
Car: 2010 Nissan Versa 1.6
Sounds good, a local member has it on his hatch and looks great. Any pics?
langkimvo
i will get some up soon
lucasdilillo
Car: NISSAN TIIDA
ADOversa
Car: 2008 Versa S 6MT Hatch, 2005 Chevy 3500 LWB
That one looks decent ^^
I can't quite picture how it attatches though.
JKDJose
Yep. I got the same one from EBAY. I put in them in both my Versa's. Makes driving much more comfortable and I love the center storage.
lucasdilillo
Car: NISSAN TIIDA
JKDJose,
did you put the armrest I mention ???
Can you install it in the cupholder??
ADOversa
lucasdilillo wrote:JKDJose,
x2!
I would love to see pics of it installed! And also to hear how you installed it. I am very interested in one for my car!
langkimvo
http://cgi.ebay.com/ebaymotors/NISSAN-V ... 5d2b2d1986
this is the one i got. its screws into the cupholder with 4 screws. its pretty sturdy .i will get pics up. but it looks like i have to have a photobucket or flicker or something.
lucasdilillo
Car: NISSAN TIIDA
I saw itsome days ago, but after that I found this one.
http://cgi.ebay.com/ebaymotors/Nissan-T ... 1133wt_939
but i do not know if it also has the same system to put it in the cup holder and the seller did not give an answer about that,
Anyone can help me?
JKDJose
Sorry for not posting for a while. Yes. I installed the one you mentioned from EBAY. It screws into the cupholder. I installed them on both my versa's with no issues.
There are 2 parts, eight screws. The first 4 screw into the lower base, then the other part screws into that base.
The lower base goes right into the cupholder and it has 4 screw holes on the top. You then put the top part on and that screws onto the lower base that's in the cup holder.
It is so much easier driving with that armrest.
Vancelot
Has anyone tried this one? I like it because it ships from the US and the armrest extends forward.
It looks like the same cup holder mount as the other one.
http://cgi.ebay.com/ebaymotors/Nissan-V ... 2767wt_939
Fendermb4
I agree, these are great.
I made one small modification to mine though:
They have a cup holder that comes out of the back of the armrest. If you put the armrest over your versa consoles front cup holder, then the one that comes out the back of the armrest is redundant, and would never be opened, because it blocks the cup holder that is already there. Because the cup holder is inside the armrest, you don't get as much space inside it, and it has a sort of false bottom to cover up the cupholder assembly. To solve this:
1. Remove the cupholder assembly - you do this when you put the armrest in anyway, so you'll know how to do it. Cut the face plate off of the cupholder using a dremel or angle grinder. This is the part that you see from outside the armrest. Here is a cupholder without the faceplate on it. You can discard this piece.
2. Stick the faceplate you just cut off onto the armrest, where it belongs. It will kind of snap in. Glue it there from the inside, using super glue. Now the cupholder won't open, but it looks the same as when the cupholder was in there.
3. Don't put the false floor back in, and enjoy your extra space. Here are before and after pics to show the extra storage.
Before:
After:
Note the back of the faceplate on the right, where you can see the cupholder was cut off. I didn't do a super neat job, but you certainly could do it neater if you cared to.
anthony870
Car: '11 Nissan Juke S 1.6L Turbo
'09 Nissan Versa S 1.8L H/B (traded)
nice work. I have the same armrest in mine. I was planning on doing the same exact thing with mine. how did you get the faceplate to stay on the hole?
@vancelot: That is a nice armrest. wish i had seen that before i got the one i have. i think that would be a better armrest for sure. when i got mine the cup holder was broken and had to fix it. still unusable because no drinks will fit in it. i do not recommend the one i get. with some modifications as shown above it can be good. but with the one you are looking at seems like you will have same results with less hassle.
Return to “Versa Technical Discussions”
