kc5f »
https://forums.nicoclub.com/kc5f-u46433.html
Thu Apr 21, 2011 6:18 am
Have you tried this from the owner manual? I imagine it's the same with newer models as with mine.
Silencing the horn beep feature
If desired, the horn beep feature can be deactivated using the keyfob.
To deactivate: Press and hold the (lock) and (unlock) buttons for at least 2 seconds. The hazard warning lights will flash three times to confirm that the horn beep feature has been deactivated.
To activate: Press and hold the (lock) and (unlock) buttons for at least 2 seconds once more. The hazard warning lights will flash once and the horn will sound once to confirm that the horn beep feature has been reactivated.
