Armada key fob for my G?
Jons_G35_sdn
Car: 2003 G35 sedan-no doggy door,91 240sx sold,04 subaru wrx stage 2
My G35 key fob dont work any more and i have an extra key fob from my parents armada can i program that one for my G, if so will i have to take it to a nissan or infiniti dealer? THANKS
zozoka1212
Car: 08 Infiniti G35x
If the same looking one it should work. I believe you can reprogram your keyfob if it is 06 or older.
here is the how.
Never tried it.
REPROGRAM KEY FOBMost Nissan VehiclesThe horn chirp can be disable by pressing the lock and unlock buttons simultaneously until the hazard lights flash, and no enable press the lock and unlock until the horn chirp.To reprogram (enter new ID) key fob (keyless remote controller) follow the steps. 1. Close all doors and lock all doors 2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds. (The hazard warning lamp will then flash.) NOTE: Key should be withdrawn from ignition key cylinder completely each time. NOTE: Do not rush the insertion/removal key cycling process. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed. 3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position At this time, the new ID code is entered and original (previous) ID codes are erase. 4. Press any button on the new remote controller once. (The hazard warning lamp will then flash) NOTE: Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed and programming is successful. If there is only one remote controller skip step 5. 5. Additional ID code entry Release the door lock, then lock again with door lock/unlock switch (In power window main switch) 6. Remove key from ignition7. Unlock driver side door, open driver side door and then close the door. (END) NOTE: If you need to activate more than two additional new remote controllers, repeat the procedure on step 5 "Additional ID code entry" for each new remote controller. NOTE: Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore. Did not work? REPROGRAM KEY FOBMost Nissan VehiclesTo reprogram (enter new ID) key fob (keyless remote controller) follow the steps. 1. Close all doors and lock all doors 2. From the door switch unlock the trunk. 3. Insert and remove the key from the ignition key cylinder six times within 10 seconds. NOTE: Key should be withdrawn from ignition key cylinder completely each time. NOTE: Do not rush the insertion/removal key cycling process. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed. NOTE: At this time, the new ID code is entered and original (previous) ID codes are erase. 4. Manually unlock and lock the driver side door 5. Push any button on the new remote controller once. If there is only one remote controller skip step 6. 6. Additional ID code entry Repeat step 4 and 5 7. END. NOTE: If you need to activate more than two additional new remote controllers, repeat the procedure on step 6 "Additional ID code entry" for each new remote controller. NOTE: Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore.
Hope this helps
Zozo
Jons_G35_sdn
Thanks ill try when my wife gets home. Hey isnt your avtar the little guy from the blah blah blah video?
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
if your FOB isn't working, put a new battery in it then do the reprogramming procedure. Battery failure could have been the cause.
Be patient, the reprogramming works but it may take a few times to get it right.
Also, if the armada FOB is the same style then it should work. If its the newer version it will not.
Jons_G35_sdn
Sweet! I did it, but how do i activate the horn when i press the lock button?
fbpem1
Jons_G35_sdn wrote:Sweet! I did it, but how do i activate the horn when i press the lock button?
hold the lock and unlock button till the lights flash
