FairladyS30 »
https://forums.nicoclub.com/fairladys30-u295483.html
Fri Apr 03, 2020 10:19 pm
Hey everyone, new member here, thanks for reading.
I have a 2004 Armada that died while I was driving. It felt like the fuel pump shut off. It'll start momentarily (starts good, like it should), then as few seconds shuts off. As if something is shutting off the fuel pump right after starting.
I've done many searches, and found a few topics regarding the ipdm ecm relay. I switched that out but no change. I've changed the crank sensor and fuel pump but it's doing the same thing.
I read that the IPDM itself could be a culprit, but the Nissan tech I had check the car out said that's unlikely. He ran the consult and there aren't any codes. I really can't afford to get into the "guess what component is broken" game, so I'm hoping someone has an idea I haven't yet considered.
This doesn't sound too uncommon, so I'm hoping someone sheds some light on this topic.
Thanks in advance!
